Best flexible filler for walls and ceilings?
11 Nov 2018
Hi all
With your experience what's the best flexible filler to fill long thin cracks in a lath and plaster ceiling and also long cracks on the walls
I've got to decorate my bedroom and there's hairline cracks everywhere!
Thanks in advance
Polyfilla advance is supposed to be good, it can be sanded, but you might need to open up the crack a little.
If the original source of the movement remains the cracks could still reappear.
Blup
Thanks blub
The cracking is due to plaster blown in areas
I've used decorators chaulk in the past but not too great to paint over
Cheers
Caulk can leave a sheen which shows through paint unless primed.
Blup
Ok thanks do you Think polycell should be ok to use If the plaster is blown slightly in places?
I use Toupret Fibacryl.
http://www.toupret.co.uk/business-customers/products/specialist-solutions/fibacryl-FIBACP01G.html
I purchase the version in a caulking tube. First I brush PVA in to the gap in the hope of "locking" the loose plaster. I then squirt the toupret in to the gap. Smooth if off with a filling knife and then wait for it to shrink back. It is like caulk with tiny fibres, it will shrink back a lot. Deep cracks I leave for a couple of days. I then over fill with Toupret Redlite and sand flat.
I have only been using the Fibacryl for a couple of years but I have been happy with it thus far. Previously I used their powdered filler with fibres and was unimpressed when it hairline cracks appeared after a couple of months. I think they may have discontinued that version, I can't find it on their site anymore.
Polyfilla is dreadful stuff now it was good when I started as a Painter and Decorator 33 years ago, now when you fill with it , it feels like rubbing down tile adhesive, like above Toupret is fantastic, not cheap but you get what you pay for
