I have a set of chinese bumper reflector LEDs. The front is the red lens and it's glued together with what looks like some sort of clear resin. However, after 1 and half years moisture seems to have made it's way inside the red lens. Even though I applied a thin layer of tiger seal sealant around the edge. So I'm thinking the tiger seal thin layer wasn't strong enough. So now I'm thinking to possibly use some sort of ePoxy. I wanted to put superglue but I've read that it's not water resistant and will break up when exposed to mosture and water. I've used 2 part ePoxy glues in the past which have also come of as a hard thin layer of glue. So question is, does anyone know a glue that I can use (ideally brush on) that can become rock hard and also seal the backing plate to the lens ?
