Best LED Lamps
11 Jan 2004
As some may remember, I was a big fan of Osram lamps when I was S/E.
I find them harder to get hold of these days. I started using LedHut, but now they have been taken over, I don't rate them much.
Amazon do a raft of lamps, but most of them have obscure names.
Paul Russells is one of these brands I have never heard of. But the spec seems impressive, compared to others.
Lamp life of 30K, 270 degree beam, and made to safety standard EN62560. I can't find many others on Amazon who state this.
Has anyone bought these?
If not, which lamp brand(s) do you trust?
Megaman are very good in my limited experience, but quite expensive.
OK. I must admit, I bought some cheap Chinese 10W GU10s for the lounge that have lasted well considering how much they get used.
They were recommended by a neighbour.
Out of 8, two have popped off, one only yesterday.
LEDHut sell a lot of Energizer lamps, but the lamp life compared to others is not good.
Thanks guys, Astra, I shall look up the Pro-elec. I wonder if they are made by somebody for CPC?
Andy, what Energizer colour temp do you use?
Just bought some Pro-elec 5W E14 golfballs 2700 for 1.44 each from CPC. See how they go.
Thanks everyone.
I use what ever HomeBargains, B&M Bargains, or Lidi have in stock. On the odd time Screwfix or Link if buying something else. In the main Energizer but in LED times I have only had 6 lamps fail and 4 were silly 0.58W G5.3 from PoundWorld so they don't count, so one G9 and one replacement for a fluorescent both bought from electrical whole sale outlets. I think the problem with G9 is the fitting has glass over the bulb, [quote="422.3.1 Note BS7671:2008[/quote]A luminaire with a lamp that could eject flammable materials in case of failure should be constructed with a safety
protective shield for the lamp in accordance with the manufacturer's instructions.[/quote] This means G9 lamps nearly always have glass over the bulbs so the LED runs hotter.
I would say there are three things we look for in a bulb.
1) Long life.
2) Good lumen per watt.
3) No flicker.
The last two are affected by bulb size and if they can be dimmed. HomeBargains did two Energizer E14 candle bulbs around 6 watt mark, one could be dimmed the other could not, and the was a marked difference in lumen per watt, and cost. However once out of the packet I don't think I could identify which was which, and with a life of around 6 years to remember what you bought and from where would be hard, only where lights are left one 24/7 could you really compare lamps.
So your left with flicker, I have only noted flicker when using electronic switching, and then you don't really know if it is the switch or the lamp, likely some thing in the switch is reacting with the lamp, so likely both at fault. The Energizer (or any other make) E14 and BA22d have not shown any flicker with electronic switches, had a little problem with GU10 but not sure what make, and a lot of problems with G9 mainly MiniSun, but as to if make or type can't really say.
After buying 16 Philips 8W CFL globe bulbs which started failing after a year, and by the second year most had been replaced, I steer clear of expensive bulbs, it seems cheap bulbs last longer, but the reports on the corn bulbs with live part you can touch does make one wary, I have asked the question with BA22d bulbs where the shell is metal should the shell be earthed? It is about the only class two item you can buy that does not have the class II mark
with screw and pin bulbs there are only two connections any way, but with bayonet bulbs some do use the shell as a connection, mainly 12 and 24 volt in motor vehicles, but you have a BA22d bulb with three connections and nothing on the bulb to say if the shell should be earthed, with bulb removed the bulb holder is about the only item not complying with the IPXXB or IP2X ratting as it is only exposed when replacing parts, as a small boy that was the only shock I ever got, a push switch on the counter light had failed stuck on, so dad had removed the bulb, and daft me stuck my finger in the hole.
I've found Aurora Enlite to be very good, 1 failure out of 28 in over 3 years.
Always found the LEDHut ones were terrible at dimming.
From my experience I've had zero failures from the TCP and LEDlite (LEDlite are TLC own brand) LED lamps with Philips a close second, the Dial brand from B&Q are decent too. The poorest performers for me are Osram, every lamp of theirs I've bought has failed prematurely. My go to lamps are always TCP if I can get hold of them.
Enlite Aurora are very good and they do the range, good performance and they last. I think Aurora have just dropped the name Enlite and now all called Aurora although could be wrong on that.
I have never had a Diall lamp fail prematurely, or at all in fact I & I have some that are over 4 years old now and are used regularly. Available from B&Q and Screwfix.
