Best metal paints
16 Aug 2010
Middlesex
Hello and thank you for looking at this post.
Which is / are the best paint(s) for a currently unpainted galvanised metal frame? It would be a silver / grey finish.
Is Hammerite still the paint to go for?
Thank you.
There is a little more to painting a galvanised suface than applying a coat of paint, first you should establish whether the frame has been etched, this if done will offer you a shimmering appearance and is well visable with the naked eye. Secondly you will need to apply the correct primer, and in your case a mordant solution would be the way to go, Dulux being about the best you'll get.
As for finish coats look at Rustolem or perhaps Dulux Trade Metalshield, available in both gloss or Satin.
Dec
Forgive me, I did'nt get that quite right, I am rather tired, if the frame has not been etched then you will need to apply a mordant solution, followed by a zinc phosphate primer prior to your finish coats, Dulux Trade stock both products.
My apolgies for any confusion,
Dec
Thank you for asking, if you get or come across any difficulty in obtaining the suggested products or indeed the same with application, please feel free to ask again.
Dec
I would still recommend Hammerite, It is a direct to metal paint which comes in a variety of shades, and has a slightly hammered texture when dry. It is sold in the UK.
