I am putting up backing boards for tiling on a breeze block wall.
To ensure the bath fits well, I need the finished wall about 33mm forward of the blockwork. I understand this can be done by dot and dab (indeed the old plasterboard had 20mm dabs) but having never tried this I’m reluctant to ‘cut my teeth’ on it at such depths. So am planning to fix 22x48mm battens to the blockwork, then fix the 10mm backing boards to these.
My plan is to temporarily put the battens up with a good bead of pink grip / grip fill, tapping them plumb, then waiting 24h for the glue to go off (filling any gaps in the process). Then, once the glue is solid, fixing the boards with long screws and plugs, through the battens into the blockwork.
This sound feasible? Thanks
