- Joined
- 2 Jan 2004
- Messages
- 9
- Reaction score
- 1
- Country
I replaced the boiler last summer and took the opportunity to put in a 3 port valve to enable the hot water circuit to be pumped rather than gravity fed. I left the pump on the return rather than the flow side of the boiler. I suffered from pumping over and temporarily cured this by reducing pump speed. The problem I then had was that a couple of the TRV's went noisey. I replaced them but one has gone again after only a few months. Early morning startup: tap tap tap tap bl**dy tap. It drives me crackers.
I am about to fit a new bathroom suite and cylinder and want to take the opportunity to sort this out. I had intended re-plumbing the pump to be on the flow side of the boiler (adjacent to the boiler) and then into the 3 port valve. On the hot water side of the valve I propose to enter the cylinder primary at the bottom (apparently this helps convection heating) and on the output from the cylinder connect the vent and then the cold water feed (within 150mm of each other) before return to the boiler. There is little opportunity for me to put the cold feed/vent before the 3 port valve - to do so would require me pulling the house apart. Does this sound okay? Have I got the order right?
A second question: I want to take a feed from the primary to heat a towel rail in the adjacent bathroom, which should allow me hot towels in the summer when the heatings off. Is it okay to shunt the primary circuit like this?
