Best (straightest) wood for tile battens
21 Feb 2009
Cleveland
I need a few meters of wood to batten around our bathroom prior to tiling (8.5 meters to be exact).
What is the best type/size of wood to use?
Every piece of wood I pick up and inspect in both of the big DIY sheds is bent.
So are there any (better) alternatives to using wood?
The tiles are ceramic 20cm x 50cm and 7mm thick, if that has any relevance.
Thanks in advance
As a rule a little bend can be pulled out when you level & screw to the wall, but if you want to push the boat out you can buy stripwood, it's usually in a seprate display and is knot split and as a rule warp free. Mind you there is a high premimum for wood that will end up smothered in adhesive and binned at the end.
This sort of stuff B&Q sell it too.
http://www.wickes.co.uk/invt/129300
Of course you can get these but to be frank I suspect it's more trouble than it's worth for a one off job.
http://www.screwfix.com/p/suretile-...ling-batten-set-2-25m/16963?_requestid=40861#
