I'm soon to lay 15mm thick engineered flooring in my living area.
The existing floor is 18mm thick chipboard and I'm just going to lay the flooring on top (floating floor, glued at tongue and groove joints). There was carpet down previously.
I'm a bit bemused by the ranges of underlay available. Seem to range from £15 to £65 a roll.
I'm assuming that a DPM will not be required as there's not been a DPM before, but I would like a bit of sound reduction.
Given that the existing chip floor will be fairly flat will a simple 3mm thick foam type underlay be sufficient?
Any pointers?
My flooring will be coming from Carpenters of York.
Any pointers?
