Best Value for Money multi-tool blades?
6 Sep 2016
Good day Sirs,
Can anyone recommend me which multi-tool blades you have found to be the best and provide the best value for money?
I have had a couple of bosch blades,some cheap $1 blades from china, than also I got given few free saxton blades ( not impressed with them, no different really than the cheap $1 chinese blades but more expensive) , I heard that the fein blades are pretty good.
value for money at least for me means- I will buy a £10 blade if it will last me 5x longer than a £1 blade and will give better/faster cut.
If however a £5 blade is only a bit better than £1 blade I will use the £1 stuff.
thanks.
For wood, look out for the Japanese blades from Rutland's when they come up on offer. Even when not on offer, the £7 cost when bought in a pack of ten is not too bad.
Damn... that's just madness , to buy 10 blades costs the same as I paid for my new makita multitool.
i like both saxton and rutland blades
if you are crude cutting to masonery walls brick or concrete use a cheap or old blade stop short by 3-5mm and use an old blade to finish
