Hi
I am building a partition wall in our detached double garage to house a reptile house.
The exterior walls are double skinned up to about 70% of the wall height.
I am using 38mm x 89mm timber for the stud wall.
We will eventually be putting a door into this area from the exterior of the garage and an internal door into the garage area.
We are on a bit of a budget so I was trying to find out what that best value insulation is as celotex is so so expensive.
I was also hoping to insulate the exterior walls of the new walled area.
I have confirmed with building regs that these changes do not require an application
