Best way to add thread to a tube
25 Feb 2016
Hello,
I am trying to add a thread to a tube so that I can attach glides/machine feet, what would be the best product for the job? I have looked at a lot of options, with threaded tube inserts being one of the best looking and simple to fit.
Examples of what i've currently looked at;
http://www.vital-parts.co.uk/tube-inserts-20-c.asp
https://www.google.co.uk/url?sa=i&r...SRBnKJbiDcsmwZt830fHWrdA&ust=1458293415420609
https://www.google.co.uk/search?q=t...hVOSZoKHXQnDqEQ_AUIBygC#imgrc=i4lq8KAwvQ79RM:
Thanks.
Those pop in inserts are definitely the way to go......but you need to measure the inside dimensions of your tubing carefully so you choose the correct size.
John :)
John :)
The ones with ribs? Also should I go exact sizing or should I go for a size slightly smaller or larger than the tube to give myself a bit of room?
Thanks.
The ribbed ones are hammered into the tube, and they fit very firmly.....its not the best move to get them out again for re-use! All of these fittings will state the size for what they are intended, so best to go by their specifications.
John :)
John :)
Okay thanks for the info, it looks as if threaded tube inserts may be the best route for me to go down for this.
