I have purchase a new FLUIDMASTER cistern 6lt with the inlet pipe on the bottom right hand side. My cold water feed from a copper pipe is on the opposite side. What's the best way to connect the two. In my mind it's a elbow fixture on both the inlet and cold water feed and a straight pipe between them? Instead of Flexi?
What fixtures should the elbow be, there seems to be so many types. Can is use push fit tap connectors, even on the copper cold water feed?
Would PEX pipe be the best material to use?
