Hello,
I've purchased a super king size bed but the base which the mattress sits on top of, but is covered buy the frame outside of it so can't be seen, is one large metal frame which cannot fit up my staircase , or rather than gap between the hall and stairway isn't large enough to turn it up the stairs. This frame then sits on legs to lift it off the ground while inside of the frame.
So I need to figure a way of getting it up stairs, my current thought is to cut it in two, drill holes on either side to lay a metal plate across and put a bolt through then add extra legs to the middle for support. It only comes with four, one for each corner. I'm not sure if this is the best way though so thought I'd see if anyone has any other ideas? Or even if this is the best way any tips on how to do it as I've never done anything even vaguely similar to this before.
