Best way to fill gaps in scribed skirting joints.
29 Dec 2005
London
Hi.
Just a quick question.
What is the best thing to use to fill in small gaps left in the internal corners of new skirting boards?
I have fitted the MDF skirting boards myself, so there are gaps of about 1-2 mm due to inaccurate scribing.
What do you recon? Caulk, wood filler?
Thanks,
Matt
Flexible caulk. With a very small cut in the nozzle, start at the floor and pull up in one run. Wood filler is likely to crack and open up - only takes a piece of furniture to knock into it to flex the skirting enough to crack the filler.
