Yet again we have had a joiner install 4 internal solid wood doors and mess up one of them!
Despite me providing him with a print out of the installation instructions and highlighting the bit about taking a maximum of 6mm from the top and 6mm from the bottom, he fit the door and it caught on the carpet so it took more off the bottom, MUCH more than he should have. If only he had measured the gap correctly in the first place and taken some off the top instead of trying to take it all off the bottom!
The last joiner we hired to install 3 internal doors did exactly the same to one of them. I am struggling to understand how experienced joiners are making these rookie mistakes! These doors + fitting cost over £200 each and yet they have been butchered by a joiner!
I appreciate you don't notice when the door is in place, but when I have removed the doors and their furniture to oil them, I saw what he had done to the bottom and it is now showing a lot of particle board/chipboard:
I have used Osmo High solid door oil to treat the door, so I wondered about sanding the edge down and then using Osmo oak filler, which can then be oiled. I appreciate the appearance of the bottom doesn't matter that much, but currently it is a mess as you can see, plus I want it to be sealed to prevent moisture ingress.
I would appreciate any advice on sorting this mess and I will be looking for another joiner to fit the remaining 3 doors!
