Best way to fit a shower tray
6 Aug 2009
West Midlands
Hi im interested to have the opinions of plumbers in the trade on the best way to lay a shower tray the floor is solid so would be best to use breese blocks bedded on compo then put a marine ply ontop of the breese blocks but what im not so sure on and have had varied responses from different people is how to lay the shower tray onto the plywood so would appreciate some advice
__________________
I like long walks,especially when they are taken ;)
ive used a resin shower tray with feet before, just curious of the methods used as i know many plumbers use sand and cement to bed the tray down but wondered if this causes any problems later on due to the expansion and movement in the ply does it cause the mortar to crack
My x ray vision never found a crack in the mortar under a bedded shower tray ;) Seen a few on legs that cracked when a glass bottle was dropped in it .
why would you have a glass bottle in the shower?
i was told that using plasterbaord adhesive to bed it down worked well but wasnt to sure this would stick to the timber properly or maybe floor tile cement adhesive with a latex additive so it will move with the timber
Whatever you use under the base, make sure you've got access to assemble the waste when you plonk the tray in place, and for any subsequent cleaning out of the inevitable blockages (top access waste fittings can save hassle later)
The sand/cement mix holds the tray up more than sticks it down, but it does a pretty good job of that too. The idea is the sand conforms to the exact shape of the individual tray and the flooring uderneath, so the whole tray is evenly supported so it can't rock or move about. The cement just holds the sand in place.
The sealant around the tray should cope with any small movement from swelling of the timber, which should stay dry anyway. If it doesn't, there are other problems.
