hi,
looking for a spot of advice here. recently moved into a flat which has laminate flooring, however they did not bother to remove skirting before laying it, so there are expansion gaps which i am going to hide with beading.
curious as to the best method for fixing the beading to the floor/skirting?
would it be better to use an adhesive, like No More Nails, or to use some pins?
also, is it better to fix the beading to the floor or to the skirting? i assume i would not want to fix it to both, as this would create a solid structure which may allow the possibility of warping if any expansion occurred?
thanks in advance
thanks in advance
