This is for my non internet savvy dad - so if you need more details it may take a little while to find out.
Basically system they have is 35 yrs old - header tank in loft and a hot water cylinder in an airing cupboard. Had a new boiler a couple of years ago but was connected to old cylinder/tank and both are coming to the end of their life and need replacing. He definitely wants to stick with a hot water cylinder.
The water pressure on the shower over bath has always been a bit pathetic so looking at a way to improve it at the same time. The mains water pressure is quite good (haven't got a bar/ or litre/min figure - measuring complicated by the water use reducers on mains feed taps) but the feed upstairs is only 15mm and would be a real pain to change to 22mm (2 ft thick solid stone walls, a later extension, L shaped house etc). And the main feed pipe to house is 20 m long lead pipe -probably not that big anyway.
Bathroom sink is fed by cold water mains.
Bath/Shower cold is fed from the header tank and the header tank fills the cylinder.
So he thinks he has 3 options
1. an unvented tank and a direct cold feed.
2. current cylinder/header tank set up and a pump
3. Keep current system (new cylinder/tank!) but raise the height of the header tank in loft - currently there is about 3 ft height difference between the header tank and the shower head. Tank could be moved to the gable and raised by another 3-4 ft -if not more.
So he has had a couple of plumbers to quote...
They both have said the pump approach is maybe not the best - potentially empty the tanks before they've filled....plus maintenance /replacement/failure
One thinks the unvented tank is the way to go - the other says that the pressure can only be as good as the 15 mm feed will allow so not ideal and does away with one advantage of having a tank - you have some water even if it is cut off for some reason.
He recommended raising the header tank.
Anyone have any thoughts? I thought (apart from yearly maintenance) an unvented tank would be the way to go - but now having my doubts
