Hi Guys' I wonder if you could comment on the following.. The builders cut a new doorway into my new extension going back a few months, however they had a few goes at getting the cut straight and in the right place in the inner skin to match up the the cut in the outer skin... I'm now at a point where I'm looking to finish this area and I find myself with a return into the doorway, about 8" wide (to close the gaps in what was the inner and outer walls) but about 40-50mm deep per side to get back to where the plaster needs to be and to match up onto the frame for the door.. so what do I do?... If the plasterboard is 12mm, do I put 28-38mm of dot and dab on the back of the plasterboard to make it right?... Do I dot and dab some plasterbooard to the return and then dot and dab another on top to make it right?.. or do I screw some wood in and dot and dab to that?....
any comments appreciated
