Best way to remove new render?
31 May 2013
Oxfordshire
This is a follow-up question to the thread here:
//www.diynot.com/diy/threads/wrong-colour-monocouche-how-to-fix.421747/
So I told the builders to remove the wrong render and render again with the right colour of monocouche. They started removing the render this morning and are making really slow progress. This stuff (Weber pral M) is at least 15mm thick and stuck tight. They don't want to use power tools to limit damage to the (new) walls underneath. And they seem to think they can salvage the base coat and mesh if they get the render off carefully.
Is there a trick to removing new render or do they just need to keep at it? At this rate they will be at it all week.
Cheers,
Nomis
