Got a very thin door so housemates are heard pretty loudly from my ground-floor room when they're downstairs. Even with my door closed, you can sometimes hear the faintest of nose sniffs if someone is in the kitchen or living room. I recently changed the lock on this door and during the drilling I realised it seemed to be filled with mainly paper and foil!
Before taking the plunge and investing in a soundproof door (not sure which one though?) I was wondering if there might be a way to try soundproofing my existing door. Thought I might as well give it a try beforehand just in case it works, and might save a few quid in the process.
Happened to run across a message on a since-forgotten forum some time ago where someone described how they used expanding foam in their thin door as a way to soundproof it. I'll try to find the message and quote it here later. Apparently it worked amazingly well.
Does anyone have any experience with that or any other economical soundproofing techniques? At the moment I'm thinking I should drill about 20 holes at different points on the face of the door and fill each hole with expanding foam?
