Best way to standardise wood cuts
27 Jun 2013
Yorkshire
Myself and the wife are undertaking our first DIY woodworking project, a potting bench made from chunky 2x4 redwood. Our local timber merchant has given us a great deal on the wood we need but the cuts on the 2x4's vary by up to 5mm in width. To make everything the same size what would be the best way of addressing this, cutting them down with a table saw or maybe planing them down with an electric planer?
The plan is that this is the first of many projects that we complete together (unless this mission end up with my head beneath the saw!) so we'd be looking at purchasing what we need to do the job.
Edit: the max length I'll be looking at is 2m as the wood has been cut into the size I need.
Cheesy
heeelllooo and welcome cheeseater :D :D :D
table saw is the kiddy
although if the wood is like a bannana it wont work
you will need a planer thicknesser
is it treated wood??
if so it may need to even out mousture wise 5mm would be the difference between a very dry and very wet bit off 4" timber
Making a bench ? then variation is of no consequence, leave a slight gap to allow expansion and this will also take care of slight difference in timber dimension.
Sorry I should have been more accurate. Its treated but just not sawn very accurately.
Hahaha thanks that is exactly what the 'missus says!
I agree on this project it's probably not a deal breaker but in a perfect world how would I do it?
Ta
