I've got to join together about 6 metres of aluminium and stainless steel "L" angle strips, like this (end view):
¬L
There will be a vertical load on the s/s (left hand side of the diagram) equivalent to say 50kg max over any 100mm length of the join - the extreme left hand end will be fully supported but the vertical surface will rely on the strength of the adhesion to the aluminium. The joinable vertical area is about 20mm high, and the strips come in 1-2m long sections.
I don't have the option of using rivets, bolts, welding etc.
What would be the best adhesive to use?
Any top tips for preparing the surfaces?
Thanks!
¬L
Thanks!
