Hello,
just a simple one...
I have some under cabinet kitchen lights, lv 2 transformers. I have wired a fused spur inside a unit, and taken this from the ring, the switches have to match and the range I am using is this http://www.screwfix.com/app/sfd/cat/pro.jsp?cId=101964&ts=95355&id=52648 what simple q I am asking is the switch I have pointed you 2 ok? and if so what terminals do I use. I feel a bit of a fool as I have done quite a bit in the past, normally I would have just used a switched spur and wired the transformers directly to this. but I want the nice flatplate on show. I know they do other switches in the crabtree platinum range, 20a dp, intermidiate.
Darren
Darren
