Our loft is blooming freezing and the cold air comes down into the house.
There is some insulation at floor level and it has been fully boarded. The roof is fairly new good thick slate tiles and has a breathable membrane on the back. The rafters are only about 70mm deep.
We were thinking about putting insulation between the rafters to make it a bit warmer and stop the draughts a bit.
We have had a quote for the spray foam insulation but are also considering using boards between the rafters such as kingspan or celotex.
Because our rafters are quite shallow and you are supposed to leave a 50mm gap before even putting the boards up we would only have about 20mm space for the insulation board. Is this enough? Is there anything else anyone can recommend?
Does anyone have any information on the spray type of insulation.
Sorry for being a bit vague, it's not something either of us have any knowledge of and would appreciate some real advice on.
