I live in a 1950's semi which is a solid walled, poured concrete, structure. Whilst the house itself has a wall thickness of nearly 11 inches, there is no cavity to aid noise suppression between myself and my neighbor. I've addressed the downstairs problem by installing drywall noise insulation materials on the between walls, however the upstairs presents me with a challenge. In the main bedroom, which has the between wall expanding from the front of the building to the back, it has large fitted wardrobes across them. As these wardrobes are of excellent quality I don't want to demolish them to install a similar sound insulating barrier as that of downstairs. The only thing in my favor in respect to the upstairs wardrobes is the fact that whoever installed them originally left a 2 inch gap between them and the between wall, with access to that 2 inch gap of about 8 inches from the top of the wardrobes and the ceiling. Now the main reason of my posting. It appears I can fill the space between the wardrobes and wall, but what material can I use to fill this gap and thus provide some degree of sound insulation. I thought of using fiber wool, or even fire resist polystyrene balls in this cavity, but as I will only have one shot at this, without removing the wardrobes to remove any installed materials, I would welcome any suggestions from this forum on what I should use for maximum sound suppression?
Kindest regards, John
