Our boiler has had this fault for a few months. It will run happily for a few hours then cuts out. This generally only happens on CH as we never run the hot water for more than 20 mins or so.
BG say I need a new boiler as it would cost about 1k for them to fix by replacing both heat exchangers and a flush so I would be better off bnuying a new boiler. The boiler is only 8 years old, and although not that great, does suffice for our small 2 bed cottage.
I have turned down the temp on the CH but still the rads are very hot, even though they are fitted with TRV's on about 2-3. Obvioulsy the boiler is overheationg and I assume due to limescale/sludge in the main heat exchanger? Would it be worth me trying a manual flush using some X400/X100? We did have the secondary exchanger flushed by BG over a year ago for a similar fault which worked up until now, so maybe doing the same would give us another 12mnths or so? Would it be possible to remove the main heat exchanger to flush properly or is this a corgi-only job?
Any advice greatly appreciated. Thanks.
Ben
Ben
