having problems with this boiler, first problem was flame was not igniting and we had it diagnosed as a split diaphragm, problem was fixed
Then every time we switched on hot water or constant or timer CH it ignited and after a few seconds red lock out light came on. We had someone come and repalce pump but did not cure problem ..... was this correct?
Now if we switch boiler off for a few days and back on again, hot water will work and so will constant CH, but as soon as we put it on timer, after 20 mins, flame goes out when it reaches temperature and then comes on again but then suddenyl stops and red light comes on again and this in turn affects hot water. If we give it a rest and chance to cool down it works for a bit and then bang same problem. A plumber has stated that it we probably need a new boiler, any help would be interesting
