Biasi 24S boiler carries on regardless
27 Aug 2015
My Biasi 24S has just started to show the following problem.
When the thermostat is satisfied, the pump continues to heat and circulate water.
If I switch to hot water only, the pump continues to heat and circulate water.
The only way I can control it is to switch to the Off setting.
This started happening today.
Any ideas on this?
Dave
If the heat is controlled by the hot water temperature knob then there is a fault.
You will need a gas reg engineer to fix it though.
Tony
Thanks Tony, but it was the Heating, Off, Water knob that I was turning, not the water temperature.
However, I turned to 0 overnight and when I switched to Heating this morning it fired up and has been working correctly ever since.
