biasi 24s boiler
17 Nov 2007
Lincolnshire
i have a biasi 24s boiler at first it would give you central heating but when you went to run the bath it would blow the fuse in the main switch board then it would cut out if you put a new fuse in it it would start back up again you will then get central heating but again if you run the bath it blows again any one have any ideas what this could be ??????
now both fuses have blown so now we have no water or heating cant understand what this could be....
First thing to look for is water leaks inside, then "burning" smells.
Agile would know but he called me at 7pm so he's having another late one...!
No, I have been out at a fish restaurant with a few friends in Finchley.
This is not a 24S !
Its an M90 or M96.
The diverter valve gland is leaking and the motor actuator is failed.
Both the gland and the actuator need to be changed.
It leaked because the water is dirty and so that should be addressed as well.
Tony
:D :D :D thanks for that plumbers been and sorted it out and noow were lovely and warm again cheers
