Hi
I've got a biasi 24s boiler which has an intermittent problem with the central heating (the hot water works fine).
So far have had the diaphragms changed, main heat exchanger de-scaled and whole system power flushed. Plumber is now not sure what the problem can be and the heating seems to work when he tests it!
When the heating works the temp goes up to about 80 degrees at which point the burner stops, it then re-ignites when the temp goes to about 50 degrees. I think this is how it's supposed to work.
When it doesn't work you just hear the pump going but the boiler doesn't click to start the burner. Turning the hot water on starts the burner and the central heating works.
Any ideas of what could be causing the problems?
Rob
Rob
