Hello all, I have a biasi 24s boiler that cuts out intermittently.
There is no thermal cut out, and no error light.
Sometimes the boiler will run for days before this happens,other times it may just run for an hour or so. It seems to happen more often when the boiler is working hard ie. when its cold - at the mo its winter!
When it cuts out the pump is still running, just no flame.
WHen u turn on taps u can hear the diverter actuating, but just not igniting the flame.
Over the last couple of years i have done the following work:
Diverter valve full refurb kit (to cure previous fault of no hw)
Flushed out whole system
Taken exchangers off and flushed out (with formic acid)
replaced temp sensors (electronc ones)
replaced psv
replaced gas valve - this was done by myself with guidance from ex corgi reg friend, but was never adjusted or tweaked once installed.
Could the gas valve need properly adjusting or another fault perhaps?
any ideas?
Its Damn cold and if it cuts out mid shower again I'm gonna rip the bugger off the wall!
ps. Made redundant recently and no money to pay an engineer
pps. I am a electrnics technician and can turn my hand to most tasks, and after all the work already done on this boiler don't regard myself as a novice!
replaced psv
any ideas?
