We are going to be moving shortly and my Biasi 24S has started playing up. We had issues a bit back and got some fantastic helpfrom here, to which I explained to the Engineer and he sorted it.
So, intermittent issue. Calls for DHW and CH, goes through all sequence but will not fire. Other times all ok, no problems and works
So it stopped working, same Engineer called round armed with 100's of schematics, boiler fired up, without him touching it.... blasted thing.
We discussed the issues and he was a bit unsure.
Now the boiler is doing this daily, I have discovered that if I move the timer switch for CH to on from off, then we get DHW, I then turn CH back to off and DHW continues.
We cannot run to the boiler and turn on/off CH every time we need DHW
I need to get the Engineer back in, but I don't need a head scratching session, and I cannot afford a new boiler before we move.
All help and advice will be much appreciated by my Engineer and myself.
Thanks in advance.
Thanks in advance.
