Hi all,
I moved into this 3-bed semi a year ago. There is a Biasi 24s combi boiler (fitted early 2002). The central heating pipework is a mix of 10 and 22mm and the rads are large 1970s panels. Last November, an emergency fixed price repair from Biasi resulted in a new gas valve. I'm noticing more and more that things are not quite right. The fan has started whining (bearings?) and when the shower is on, the boiler has a habit of cycling off/on. The person who swapped the gas valve assures me the min/max pressure is set up correctly, and I saw him do it.
The other day, following a bath, it shut down and I had to press the reset button. I had a peek inside and spotted some pipes with evidence of leaks/scale, and a rather perished rubber seal. On the heating side, the rads all get belting hot, but I could do with an extra one in the kitchen.
I'm thinking that a new fan, seals, fixing of leak, probably cleaning/replacement of heat exchanger(s)... all sounds like throwing a lot of money at a 10 year old cheapo combi. Does that make sense? And I want something reliable, which I'd rather see to now, than in a breakdown and/or winter!
After having read this forum a lot, I'm keen on the Atmos/Intergas (what's the deal here - are they the same?) or maybe a Veissman. I've seen too many negative comments recently on Worcester-Bosch or Vaillant. Many people round here seem to get Baxis, but I get the impression they are nothing special...
Are there any local (Teesside area) fitters on here who would be interested in such a job? I guess I need to get one or two people round to have a look?
Anything I should look our for, or ask for specifically? Are magnetic filters a good idea? Any to avoid? Do I have to have a powerflush, or is a month of x400 good enough?
Sorry for the length, but I'd appreciate any feedback.
Cheers,
Richard.
Cheers,
Richard.
