I have at home a Biasi 24s in an average 3 bed semi with 8 radiators,
HW works fine but I am sure it used to be bit hotter when set at max.
The pressure is set at 1bar but I have experimented by increasing to 1.5
The issue is with CH. The boiler fires for only 30 seconds after a few minutes repetitively
The flames switch off when the temp is about 75degrees but temp gauge continues to climb to 85+ before it comes down to about 60 degrees and burner fires up again.
The flames are blue and full for about 15-20 seconds and dies down to low for abut 5-10 seconds. The HE makes kettling noises.
Only a couple of rads heat up after about an hour. If left overnight the it locks out with the red-light coming on.
The flow pipe is untouchable hot while the return is cold.
It seems like its a circulation problem so I have replaced the pump (which was replaced only two years ago - replacing the original 13 year old one)
I turned off the d/s rads and the upstairs one heated up. Then I turned on d/s again but now non of them heat up despite hours of bleeding. The water coming out of the rads seems very clean, only slightly pale due to inhibitor put in last time I power flushed and drained the system 2 years ago.
The water drained from the boiler several times this week has been very clear with a few specks of soot.
I am advised by couple of Gas safe guys that system needs a power / flush. But I suspect HE due to condition of drained / bled water.
Could it be a knackered main HE or could it be just blocked with limescale?
