We have a Biasi combi boiler model 24S, manufactured in 1998. We once had the rubber diaphragm changed, otherwise has been running okay.
However, it has started making an odd noise since we started using the heating side of it, when the colder weather showed up. The noise shows up when the heating system is running, and then we draw off some hot tap water. It is a kind of growling noise for about 4-5 seconds, sounding like shot bearings, kind of thing.
I have also heard it when the heating is on and no hot water drawn off the sink tap.
Any boiler engineers familiar with this kind of problem and able to guess what it might be? I presume there is a diverter valve that changes things over from heating to DHW when the taps are opened up, and that is in need of replacement etc.
a) Any idea of time/costs?
b) Would it be about the time when I need to change up for a condensing boiler (gulp)?
c) Any suggestions for that cond boiler?
btw, I am not planning to do the repairs - I would just feel better talking to a repair engineer when I know what is wrong with the thing, which sounds like something I will need to do shortly.
