Hi. I have a Biasi Riva advance 32HE.
It's quite old and over the years j have become quite familiar with fixing it.
This week it has been locking out with a flue temp ntc alarm. I think this must be a common alarm, as I've had it before and actually had a spare probe. With the spare probe (which was used, but the resistance checked out ok) fitted I'm still getting the alarm.
I have ordered a brand new part. But I'm not convinced this is the root cause.
I was doing come more checks today on the PCB. And where the manual says I should have 24v at the fan, I have 36v.
Has anyone seen this before. Is the manual usually correct. Could Biasi have ran out of 24v transformers and interchanged with 36v. Or could a fault cause this.
I believe the flue probe ntc alarm means that the boiler is finding the flue gas temp to be incorrect. (not sure if too high or low).
What I'm thinking is; if the fan is seeing too much voltage, would it spin faster. Could this make the boiler unable to control the combustion temperature. Or would voltage not effect fan behaviour?
