Biasi - Error 14?
9 Dec 2015
From what I've read this is possibly a pump failure but not sure. Could it be something else?
Tap hot water comes out then cools...heats again....cools and then boiler goes into error 14.
Boiler is a Biasi Advance 30C 30KW Combi.
Pump or temp above 105 degrees C according to the manual, so could be blocked heat exchanger.
Thanks. Previous boiler's DHW exchanger used to get clogged too. System was flushed and always has a Magnaclean on the return. Will take a look.
