biasi garda bolier
11 Jan 2013
Yorkshire
hi just a question , have a boiler that will ignite maybe 2/3 times out of 10 , but as soon as i turn thie sink or bath tap on the boiler goes out then i have a fast flashing green light thank you .marg the model no is m90f.28s
hi thank you for your reply but it t turns its self of but will come back on it will work again till tap is turned on again.
Dodgy flow switch membrane. If your allowed to take the case off boiler see what the flow switch is doing. That's the brass manifold with 4 stainless screws on it, left hand side. It's got a spindle in the middle that pushes on a micro switch to commence ignition sequence.
F.F.S........for fannys sake don't touch the gas pipes or the combustion chamber..........don't go killing yourself
The voices in my speakers have now changed to orchestral music
hi there the shaft is operting on the heating side but as soon as we turn the taps on the shaft goes back in and shuts down .
