I have a Biasi GARDA HE MK2 M96A.28SM/B combi boiler.
Back in December 2012 it developed a fault where it would only produce hot water for a short time, with the flame going on and off and never staying on, although central heating worked. I called a British Gas engineer, who said it was the heat exchanger that needed replacing. After this was replaced, he recommended that we should have the central heating system flushed. So we did that too.
Everything was running fine until a few days ago... again I get no hot water.
When I turn the hot water tap on, the flame comes on in the boiler for a few seconds, then cuts out. The operation lights on the front panel show a red flashing light at the "II" position. The manual shows that this is "Other faults".
One time it did show a different fault, which the manual shows as "Faulty primary circuit (absense of flow)".
Is there anything I can do before calling in an engineer again?
