Hi folks,
I have a Biasi Garda M90F.32S combi which has just started to play silly beggars.
The boiler will fire up correctly and perform as normal during both CH & DHW mode but now and again it will shut itself off (no flame) while in either mode
When the boiler cuts out it tries to restart itself - sounds a bit like whirring ever second or two. It doesn't go into a standby mode and no red light appears on the control panel. Pressing the reset button does nothing - it continues whirring/pulsing every second or 2.
Last night when it cut off while only the CH was on the green operation light was flashing fast indicating a fault. Whether it was pure coincidence or not i don't know but i adjusted the temp dial for the heating and it kicked back into life and ran fine for the rest of the evening and the green light returned to normal.
This morning (DHW only) when it cut out while i was in the shower (yes i kid you not) the green operation light flashed 'normally'. I tried the temperature gauge 'trick' but it didn't help. A few mins later it started up fine and continued to work as normal during the wife's shower.
It's stated to happen on a daily basis..
If anyone has any suggestions i'd be grateful.
