I have a Biasi Garda HE Silver Condensing Combi, it is approx 2.5 years old.
In May this year it developed a fault on the firing pcb, whereas it burnt out the Full ignition sequence PCB at the point where the 7 pin connector plugs onto the board. The connector also melted, the pins that where affected worst were the ones feeding the fan supply. I replaced the board after checking the external electrical circuits for continuity and earth, and cleaned up the 7 pin plug. The boiler has worked fine since.
I do have a problem (from approx 12 months old) in the fact that the boiler will trip out if the condensate trap detector is left connected, the trap is clear and there appears to be no signs of tracking across the probe/detector (the boiler works fine with the detector disconnected).
Last night there was that smell of burning pcb/device again.
I am at work right now, so I will have a good look when I get back home.
The smell is definately around one of the two PCB's. Does anyone know of a similar fault or maybe common fault with this type of boiler?
