my biasi 24s is losing pressure and somebody has suggested repressurizing the expansion vessel can anybody point me in the right direction on how to do this or should i get a corgi guy in?
i normally keep pressure at 1.5 bar
but it is losing approx 0.5 bar every 24-36hrs
i was initially told it could be prv but that doesn't seem to leak unless the pressure goes up to near 3 bar and then it comes out fairly quick but i guess thats its job at that pressure.
also i checked everything else i can see, ie rad valves and pipework and i cant find anything so i really am stuck now
no unfortunately i cant there is some under the bedroom floor.
i am guessing thats where you think i should be looking?
also i am concerned with the fact i only had new rads fitted 8 weeks ago and pressure was fine before that the problem has only become noticeable in last 3-4 weeks
