I would be very grateful for any help or advice on the following.
About 3 weeks ago the boiler stopped igniting when a tap was turned on. To get hot water I just switched on the central heating. Or if the central heating was set to auto and already running we got hot water out of the tap on demand no problem.
At the time it did occur to me that this would probably be a problem that would only get worse.
...well it has.
We have no ignition now.
The boiler makes all the usual sounds apart from the final woosh to light the boiler.
I am not familiar enough to identify the specific sound of the pump or fan but like I said all sounds as usual.
‘A10 Boilers’ fitted a new PCB and Fan in June 2009 and I was devastated by the high price. £548.25.
If this is a PCB issue then I'm quite happy switching it for a refurbished board myself. However if it's anything else I will need help.
My question is:
Are there any simple things I can do to diagnose the problem?
Should I just go ahead and switch the PCB for a £50 refurb “eBay” board because its so much cheaper and would rule out one problem?
pcb (BI1305101)
At no time does the red “lock out” light come on.
The green light flashes every second and after 15 seconds has a red glow behind it.
Thanks in advance.
...well it has.
My question is:
pcb (BI1305101)
Thanks in advance.
