I have an M90E.24S which seems to have developed an odd issue. I only use the boiler every few days as it's in a house I'm renovating so I'm not there all the time.
When I do come to use it, it's generally been switched off for a couple of days since the previous visit. I switch it on for C.H. and it fires up seemingly without issue but then it'll cut the flame out after a few seconds, the fan and pump sound like they continue to run, then after a few more seconds it fires up again only for it to cut the flame out again after another few seconds. This cycle, flame on -> flame off -> flame on etc. goes on for several cycles until eventually it seems happy and the flame stays lit and all is seemingly well.
It only has this odd issue the first time it's been stood unused for a couple of days. Once it's got itself going, it doesn't seem to have an issue and it'll happily function properly for both the C.H. & D.H.W. turning on and off when requested. Even if the C.H. is turned off for a few hours it'll come back on just fine when requested again. It's only when it's been off and I come back a day or two later that it'll have to go through the flame on/off cycle on initial request for CH. If I request D.H.W. first after it's been stood a couple of days it does the same thing, flame on/off cycle a few times before finally settling (warming up?) and allowing the flame to stay lit. So the fact the C.H. and D.H.W. both cause the issue suggest to me that it shouldn't be a heat exchanger issue?
I've been using the boiler sporadically over the last year while I've been working on my house and it's worked fine over the course and this issue seems to have started in conjunction with the colder weather so I'm wondering (guessing!) if when it's left a few days in a fairly cold house something seizes up/sticks and it takes a little while/heat to free up?
When this problem occurs it never locks out and seems quite happy to re-ignite and try again and again and again etc. until the flame does stay lit and, as said, once it finally stays lit I don't have any issue with CH or DHW until I come back a day or two later.
Any ideas?
Any ideas?
