Boiler is apprx 3 year old and has stopped working, i.e. not getting any hot water or heating - pls help! The boiler tries to start-up, i.e. the pump appears to run as I have checked by removing the middle screw and the shaft is spinning, however, the fan does not run and there is no spark on the electrodes. After about 30 seconds from starting the boiler the green light flashes frequently - red light (lock out) does not come on.
Any ideas what I can check/fix...?
PS: I've checked the microswitch, i.e. pin goes in and out and I've even operated it manually by sticking a pin to make the connection whilst running hot tap but still not igniting
