Hi any guidance appreciated as my regular plumber is currently unavailable and as I'm having to call in a new one. Any info would be greatly appreciated to help when discussing this with them. I wouldn't usually but as a few I've called are mentioning a new boiler given the age before coming out a sanity check would be appreciated.
My Biasi m96.28sm/c combi boiler (at least 14 years old) developed a leak from the pumps air purge valve (part BI1212107). This was a weep\drip that would happen for a short period then reach an equilibrium and stop, often stopping for months at a time. This has been happening for approx 1 year. If a radiator was bled the drip would start again and often if a lot of air was bled the leak would be more significant. It would however always stop I presume once the system reached a balance. Note Radiators were only being bled where a radiator was cold at the top and the leak had slipped my mind.
The pumps air purge valve was replaced and whilst this prevented the leak from the purge valve, the same behaviour is now exhibited from the diverter valve, with the leak coming from where the actuator connects.
I cannot confirm the pressure of the central heating system as the pressure valve has always been stuck at 0.7'ish regardless of the system being emptied, filled, bled etc..
The central heating and hot water work on demand. There are no error codes being displayed and the only issue this appears to cause are the occasional weep\leak from the diverter once it has settled (originally the pumps air purge valve)
Also noticed in case it helps
1. A single radiator heats up slightly when running hot water to the shower (this may have happened prior to the leak)
2. There is air in the system as the bathroom radiator (highest point) only heats half way up the vertical height of the rad.
It would appear that the system has an issue with pressure and the weakest point currently is the diverter.
Does this sound like a fault that could be repaired or is it likely not worth the cost in man hours to swap out parts?
A.
A.
