I'm not a plumber so if this sounds like it needs a gas safe engineer please just say and I'll call one in, but just in case I can fix it myself or to make sure I'm being told the right thing I'd appreciate some guidance.
My Biasi Riva Compact HE boiler (M96.28SM) appears to have 2 faults
1. The frost protection mode comes on for about 30 seconds once an hour (fault lights indicate Faulty c.h. temperature probe NTC when this happens)
2. The pressure gauge was reading approx 0.2 bar. I have tried adding more water via the filling loop and bleeding the rads but the gauge didn't move. It also doesn't move when he boiler is running ( I assume pressure would increase under heating ). Strangely later in the evening the pressure rose to approx 0.4 bar the heating and hot water hadn't been used other than the frost protection mode kicking in a few times.
Other than this both central heating and hot water are functioning correctly.
Can I change the temp sensors myself or is removing the cover of the boiler a no no. I don't suppose boilers are like computers given the amount of circuitry and they just need switching off and on again.
Andrew
Andrew
