No hot water but heating is fine, I changed diverter valve, dhw flow switch and dhw heat exchanger still no hot water, however the boiler gets very excited when the hot water tap is switched on. Could it be that dhw heat exchanger i put in is for 24s?? I assume they both will fit.
Thank you
Thank you
