I have a biasi riva advance 32HE. Its about 3 years old.
The DHW temperature is cycling. The water is getting up to full temperature, then it cuts out and runs cold, sometimes the burners will reignite and it will continue to cycle from hot to cold.
Sometimes the thermal cut out will cut in and the boiler has to be reset. It also appears to be venting out of the overheating pipe that goes through the wall to the outside.
So far I have:
Checked the resistance of the DHW temp sensor. It seemed ok, but I replaced it anyway as it was only 4 quid.
Checked that the over temp sensor was reading closed circuit. It was.
So basically it seems that the boiler is getting too hot......or at least it thinks it is too hot.
The manual suggests that the fan could give issues with temperature stability. Does this sound reasonable, does anyone have any advice for checks on this - the manual doesn't say much?
Cheers, Dan
So far I have:
Cheers, Dan
